How to validate 2 service criteria and create alert
Post Reply
prashant.v01
Post by prashant.v01 »
Hi Team,
Currently we are monitoring Memory & SWAP memory seperatly to create a alert once threshold is breached.
Now I want to generate a alert once Memory utilization & SWAP memory utilization of agent server is reached to 90% & 70%.
Means it should create a alert only above two condition are true on server.
Please help to achieve following requirement using ncpa.py plugin.
Thanks in Advance.
kg2857
Re: How to validate 2 service criteria and create alert
Post by kg2857 »
Look for a plugin that does what you want on the exchange or write one yourself.
prashant.v01
Can you please help me with plugin details, or help to write script to achieve requirement.
Post Reply
