check_mailq issue on localhost
scottjw
Post by scottjw »
I am trying to get the check_mailq command working on my Nagios install and not having much luck. I have spent the last two hours googling and not been able to resolve so hoping some kind sole can help.
I am using sendmail and want to check the mail queue on the Nagios localhost (I have issues where my SMTP relay goes offline and alert emails don't get sent).
Using Nagios Core 3.2.3
The command:
        command_name    check_mailq
        command_line    $USER1$/check_mailq -w 3 -c 5 -v 9 -M sendmail
The service:
        use 					generic-service
        host_name               itmonitor
        service_description     SMTP Mail Queue
        check_command           check_mailq
From command line as root:
$ /usr/lib/nagios/plugins/check_mailq -w 3 -c 5 -v 9
OK: mailq is empty|unsent=0;3;5;0
Checking with Nagios user (I think this is right):
$ su -s /bin/bash nagios -c '/usr/lib/nagios/plugins/check_mailq -w 3 -c 5 -v 9'
Nagios CGI shows:
ERROR: is not executable by (uid 1001:gid(1001 1001 1002))
From the CGI it suggests the Nagios user doesn't have permissions, but I don't understand why it works from the command line with the Nagios user.
Any advice would be greatly appreciated!
Regards,
Scott
Re: check_mailq issue on localhost
Post by slansing »
Could you please do a permissions check just to make sure something strange is going on?
cd /usr/local/nagios/libexec
ll
And check back in with the full listing of check_mailq?
Example:
-rwxrwxrwx  1 nagios nagios  20367 Apr 26 03:37 check_mailq
scottjw
Post by scottjw »
Hi slansing,
ls -l output:
-rwxr-xr-x 1 nagios nagios  20367 2011-07-01 14:47 check_mailq
Looks different to yours..
Regards,
Scott
nscott
Post by nscott »
Are you using SELinux or any of its equivalents?
Also, try settings the suid bit:
chown root:root /usr/lib/nagios/plugins/check_mailq
chmod u+s /usr/lib/nagios/plugins/check_mailq
Your current config is using chmod 755, if the suid bit doesn't fix it, you can try
chown nagios.nagcmd /usr/lib/nagios/plugins/check_mailq
chmod 777 /usr/lib/nagios/plugins/check_mailq
Nicholas Scott
scottjw
Post by scottjw »
I'm using Ubuntu 10.04.4 LTS which is fully patched and up to date.
Unfortunately I still have the same result after trying the suid and 777 chmod. Confirmed from the command line again and it still works fine:
