check_http 400 and 404 for popular websites
Post Reply
eimrek
Post by eimrek »
Hi! I need checks for external links on my website and I'm running into problems with check_http for some websites.
See these examples:
1. www.nature.com, gives 400 Bad Request
$ check_http -I www.nature.com -v
GET / HTTP/1.0
User-Agent: check_http/v2.2 (monitoring-plugins 2.2)
Connection: close
http://www.nature.com:80/ is 694 characters
STATUS: HTTP/1.1 400 Bad Request
**** HEADER ****
Connection: close
Content-Length: 273
Content-Type: text/html; charset=UTF-8
Referrer-Policy: no-referrer
X-Cdn-Origin: SNPaaS
Accept-Ranges: bytes
Date: Thu, 06 Jul 2023 16:12:21 GMT
Via: 1.1 varnish
X-Served-By: cache-fra-eddf8230033-FRA
X-Cache: MISS
X-Cache-Hits: 0
X-Timer: S1688659941.052221,VS0,VE102
alt-svc: h3=":443";ma=86400,h3-29=":443";ma=86400,h3-27=":443";ma=86400
**** CONTENT ****
<html><head>
<meta http-equiv="content-type" content="text/html;charset=utf-8">
<title>400 Bad Request</title>
</head>
<body text=#000000 bgcolor=#ffffff>
<h1>Error: Bad Request</h1>
<h2>Your client has issued a malformed or illegal request.</h2>
<h2></h2>
</body></html>
HTTP WARNING: HTTP/1.1 400 Bad Request - 694 bytes in 0.125 second response time |time=0.124696s;;;0.000000;10.000000 size=694B;;;0
2. www.snf.ch, gives 404 Not Found
$ check_http -I www.snf.ch -v
GET / HTTP/1.0
Connection: close
http://www.snf.ch:80/ is 274 characters
STATUS: HTTP/1.1 404 Not Found
**** HEADER ****
Date: Thu, 06 Jul 2023 16:15:26 GMT
Content-Length: 146
Connection: close
**** CONTENT ****
<html>
<head><title>404 Not Found</title></head>
<body>
<center><h1>404 Not Found</h1></center>
<hr><center>nginx</center>
</body>
</html>
HTTP WARNING: HTTP/1.1 404 Not Found - 274 bytes in 0.013 second response time |time=0.013416s;;;0.000000;10.000000 size=274B;;;0
Both of these websites work well with curl and wget on the same server.
Version:
$ icinga2 -V
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.3-1)
Other websites, such as www.google.com work well.
I have tried to mess around with all the various options (-f, -A, -S, ...) but nothing seems to work. Does anybody have any ideas how to make this work?
kg2857
Re: check_http 400 and 404 for popular websites
Post by kg2857 »
-I means the arg is an IP address. Try reading the -h output and correcting the syntax.
eimrek
Post by eimrek »
Thanks! any idea why
$ check_http -I www.google.com
HTTP OK: HTTP/1.0 200 OK - 19572 bytes in 0.157 second response time |time=0.156920s;;;0.000000;10.000000 size=19572B;;;0
works?
Post Reply
