How to implement Splunk effectively?
Post Reply
SomeenKopatri
Post by SomeenKopatri »
How can Splunk and Nagios Log Server be effectively implemented in an organization as per the boss's request?
kg2857
Re: How to implement Splunk effectively?
Post by kg2857 »
Nobody can answer based on the total lack of info in the question.
hyang
Post by hyang »
Hi @SomeenKopatri,
It really depends on your environments needs. There are different use cases for Log Server. I'd recommend to set up a test server of Log Server and fiddle around with it. There is a bunch of documentation/videos/tutorials that you can check out to have Log Server effectively implemented.
Documentation
Videos/Tutorials
Webinar
Best of luck on whatever you do!
Post Reply
