Dear All,
My Nagios XI Server is not accessible in GUI, where do I find the License Key.
Abdulla
Finding License file for Key transfer
Re: Finding License file for Key transfer
Hi @afayez,
Have you bought a license for Nagios XI? I recommend to email [email protected] if you haven't received your license information. Otherwise you can choose the trial option when you are setting up XI or choose the free option which is limited to 7 nodes and up to a total of 100 host/service checks. Check out this video if you need help starting up XI.
Best Regards~~
Best Regards~~
