Issue - Acknowledge Problem
Post Reply
op-team
Post by op-team »
Yesterday I successfuly upgraded my XI from 5.10.0 to 5.11.2
I found an error when trying to acknowledge a problem
The field 'Author' is not autocompleted and it is not possible to fill it manually
Thank in advance for your help
sgardil
Re: Issue - Acknowledge Problem
Post by sgardil »
Hey @op-team
Thanks for reaching out and sorry for the inconvenience. This has been noted and there is a fix in for the next release. In the mean time if you want to fix the issue and still have 5.11.2 version, I attached a file to this post and you can unzip the file and replace the current file with the attached file. The file location is /usr/local/nagiosxi/html/includes/components/xicore/status-object-detail.inc.php . Or if you don't mind getting into the code you can replace all instances of
<?php echo $current_ccm_alias; ?>
with this code
<?php echo get_user_attr(0, 'name'); ?>
op-team
Post by op-team »
The change have solved the issue
You can close this topic
Post Reply
