XI 2024 | Highchart dashlet host_name link is broken
Post Reply
snapier3
Post by snapier3 »
The Highchart dashlet is creating malformed hyperlinks for the hosts in hostgroup.
Linux-Servers-->Localhost
The hyperlink URL is targeting hostgroup:host_name vs host:host_name
Hyperlink takes you to
gwesterman
Re: XI 2024 | Highchart dashlet host_name link is broken
Post by gwesterman »
Hi @snapier3,
Thank you for reporting this. It has been noted and will be addressed in future releases!
Thank you!
snapier3
Post by snapier3 »
Here's the fix:
There is a snafu in the "make_highchart.php" file of the dashlet.
Replace the OG if/else with the following snippet
	#MODIFIED BY S.Napier3
        #DEC 07, 2023
        #FIXES HOSTNAME LINK BUG
        if ($link_labels){
            $base_url = '/nagiosxi/includes/components/xicore/status.php?show=';
            #CHART HOSTGROUP MEMBERS OR ALL HOSTS
            if (grab_request_var("hostgroupChoiceSelect","default") !== "default"){
                #WE HAVE A HOSTGROUP APPEND IT TO THE URL
                $base_url .= 'hosts&hostgroup='.grab_request_var("hostgroupChoiceSelect");
                #HOSTGROUP LABELS
                $output .=
                'labels: {
                    formatter: function () {
                        return "<a href=' . $base_url . ' target=' . '_blank' . '>" + this.value + "</a>"
                    useHTML: true
            else {
                #WE DO NOT HAVE A HOSTGROUP
                $base_url .= 'hostdetail&host=';
                #PER HOST HOST DETAIL LINK
                $output .=
                'labels: {
                        return "<a href=' . $base_url . '" + this.value + " target=' . '_blank' . '>" + this.value + "</a>"
                    useHTML: true
            #BACK TO YOUR REGULAR PROGRAM
This will correct the broken links with ones that work ;)
sgardil
Post by sgardil »
Hey @snapier3
Thanks for sharing the fix you found. If people are uncomfortable with modifying the code and are bothered by this issue, you can keep an eye out on the changelog for a fix in the future for this issue. https://www.nagios.com/changelog/
Post Reply
