Nagios XI 2024R1 upgrade bug
Post Reply
hbouma
Post by hbouma »
The upgrade script does not work if you have an offloaded database. Everything is setup expecting localhost or the mysql commands are run without specifying the offloaded server name.
The file /tmp/nagiosxi/nagiosxi/nagiosxi-db/mods/mysql/schema_60000_root.sql file assumes that everything is on localhost instead of an offloaded database. In addition, the SQL command does not pass the -h and database server. For instance:
mysql -u root --password="$mysqlpass" -h $cfg__db_info__nagiosxi__dbserver < nagiosxi/nagiosxi-db/mods/mysql/schema_60000_root.sql
Lastly, the commands will never work because the offloaded database instructions do not create the "GRANT OPTION" for the root user. https://assets.nagios.com/downloads/nag ... Server.pdf has the following on page 11:
GRANT ALL ON *.* TO root@'<IP_OF_NAGIOS_XI_SERVER>';
But it should read:
GRANT ALL ON *.* TO root@'<IP_OF_NAGIOS_XI_SERVER>' WITH GRANT OPTION;
jmichaelson
Re: Nagios XI 2024R1 upgrade bug
Post by jmichaelson »
I'm sorry about that. I'll open up an issue for the problem.
-Jason
hbouma
Post by hbouma »
One last bug.
This is using mysqlpass from /usr/local/nagiosxi/var/xi-sys.cfg, however, that is never changed when you offload a database, so it is incorrect.
You may want to update the offload database instructions to change that password as well.
sgardil
Post by sgardil »
Thanks for letting us know about this issue, I will add it to the issue made, and will also make note for upgrading the instructions for offloading the database.
Post Reply
