Issue with Check HP Modular Smart Array
gm_rajkumar
Im trying to this Check HP Modular Smart Array (msa) sensors https://www.monitoringexchange.org/inve ... 29-sensors while executing this plugin. Im getting below error message.
# /usr/bin/perl5.8.8 check_msa_hardware.pl
Parameter to use lib must be directory, not file at check_msa_hardware.pl line 24
Can't locate Nagios/Plugin.pm in @INC (@INC contains: /usr/local/nagios/libexec /usr/bin/perl5.8.8 /usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl /usr/lib/perl5/5.8.8/i386-linux-thread-multi /usr/lib/perl5/5.8.8 .) at check_msa_hardware.pl line 28.
BEGIN failed--compilation aborted at check_msa_hardware.pl line 28.
Regards,
Raj.
Regards,
Raj.
Re: Issue with Check HP Modular Smart Array
Raj,
Looks like your missing some perl module.
Try installing Config::Tiny as root using cpan.
perl -MCPAN -e 'install Config::Tiny'
Regards,
-Yancy
Regards,
-Yancy
gm_rajkumar
I tried, got below result.
CPAN: Storable loaded ok
Going to read /root/.cpan/Metadata
Database was generated on Tue, 31 Jul 2012 13:12:26 GMT
CPAN: LWP::UserAgent loaded ok
Fetching with LWP:
ftp://ftp.perl.org/pub/CPAN/authors/01mailrc.txt.gz
Going to read /root/.cpan/sources/authors/01mailrc.txt.gz
CPAN: Compress::Zlib loaded ok
Fetching with LWP:
ftp://ftp.perl.org/pub/CPAN/modules/02p ... ils.txt.gz
Going to read /root/.cpan/sources/modules/02packages.details.txt.gz
Database was generated on Sun, 29 Jul 2012 10:14:45 GMT
There's a new CPAN.pm version (v1.9800) available!
[Current version is v1.7602]
You might want to try
install Bundle::CPAN
reload cpan
without quitting the current session. It should be a seamless upgrade
while we are running...
Fetching with LWP:
ftp://ftp.perl.org/pub/CPAN/modules/03modlist.data.gz
Going to read /root/.cpan/sources/modules/03modlist.data.gz
Going to write /root/.cpan/Metadata
Config::Tiny is up to date.
[root@monitoring libexec]# ./check_msa_hardware.pl --help
Parameter to use lib must be directory, not file at ./check_msa_hardware.pl line 24
Can't locate Nagios/Plugin.pm in @INC (@INC contains: /usr/local/nagios/libexec /usr/bin/perl5.8.8 /usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl /usr/lib/perl5/5.8.8/i386-linux-thread-multi /usr/lib/perl5/5.8.8 .) at ./check_msa_hardware.pl line 28.
BEGIN failed--compilation aborted at ./check_msa_hardware.pl line 28.
Fetching with LWP:
Fetching with LWP:
reload cpan
Fetching with LWP:
Hmm. Take a look at:
http://exchange.nagios.org/directory/Pl ... st/details
at the bottom of the page is a listing of the different perl modules that needed to be installed.
try installing these/making sure they are updated:
perl -MCPAN -e 'install Nagios::Plugin'
perl -MCPAN -e 'install Params::Validate'
perl -MCPAN -e 'install Math::Calc::Units'
perl -MCPAN -e 'install Class::Accessor::Fast'
-Yancy
-Yancy
gm_rajkumar
When i tried to run perl -MCPAN -e 'install Nagios::Plugin'
the following error occurs
Failed Test Stat Wstat Total Fail Failed List of Failed
t/Nagios-Plugin-01.t 255 65280 15 29 193.33% 1-15
t/Nagios-Plugin-02.t 255 65280 103 205 199.03% 1-103
t/Nagios-Plugin-03.t 255 65280 61 119 195.08% 1 3-61
t/Nagios-Plugin-04.t 255 65280 30 59 196.67% 1-30
t/Nagios-Plugin-Functions-01.t 255 65280 113 225 199.12% 1-113
t/Nagios-Plugin-Functions-02.t 255 65280 37 73 197.30% 1-37
t/Nagios-Plugin-Functions-03.t 255 65280 8 15 187.50% 1-8
t/Nagios-Plugin-Getopt-01.t 255 65280 76 151 198.68% 1-76
t/Nagios-Plugin-Getopt-02.t 255 65280 14 27 192.86% 1-14
t/Nagios-Plugin-Getopt-03.t 255 65280 1 1 100.00% 1
t/Nagios-Plugin-Getopt-04.t 255 65280 11 21 190.91% 1-11
t/Nagios-Plugin-Performance-02.t 3 768 3 4 133.33% 1-2 4
t/Nagios-Plugin-Performance.t 255 65280 ?? ?? % ??
t/Nagios-Plugin-Range.t 255 65280 151 301 199.34% 1-151
t/Nagios-Plugin-Threshold.t 255 65280 93 183 196.77% 1 3-93
t/check_stuff.t 13 3328 14 13 92.86% 1-10 12-14
Failed 16/16 test scripts, 0.00% okay. 726/730 subtests failed, 0.55% okay.
make: *** [test_dynamic] Error 255
/usr/bin/make test -- NOT OK
Running make install
make test had returned bad status, won't install without force
Raj,
What was the result of installing these perl modules?
-Yancy
-Yancy
gm_rajkumar
I have executed this command, there is no issue on Calc::Units and Accessor::Fast. However, i have got some error message on Params::Validate file and enclosed in this. please have a look into this.
[root@monitoring libexec]# perl -MCPAN -e 'install Math::Calc::Units'
Math::Calc::Units is up to date.
[root@monitoring libexec]# perl -MCPAN -e 'install Class::Accessor::Fast'
Class::Accessor::Fast is up to date.
param-validate.txt- perl -MCPAN -e 'install Params::Validate' result
- (17.34 KiB) Downloaded 277 times
What version of linux and architecture type are you running?
can you post the following:
uname -r
cat /etc/*release*
uname -r
cat /etc/*release*
gm_rajkumar
[root@monitoring libexec]# uname -r
2.6.18-308.8.1.el5
root@monitoring etc]# cat redhat-release
Red Hat Enterprise Linux Server release 5.8 (Tikanga)
let me know if you need further details.
2.6.18-308.8.1.el5
Raj,
open cpan
and force install of Nagios::Plugin
-Yancy
open cpan
cpan Code: Select all
force install Nagios::Plugin
