DHCP error just came back
benningtonr
Post by benningtonr »
I just started getting:
CRITICAL: No DHCPOFFERs were received.
at the command line with
[ronb@nagios libexec]$ service iptables stop
[ronb@nagios libexec]$ ./check_dhcp
[ronb@nagios libexec]$ ./check_dhcp -s 192.168.99.73
nscott
Re: DHCP error just came back
Post by nscott »
Sounds like your DHCP server isn't working properly, are you sure this isn't what Nagios is for? Has the Nagios server's MAC been blacklisted for too many DHCP requests?
Nicholas Scott
benningtonr
I have just looked at the DHCP server again, and there are no problems. The event logs are clean, and it has over 100 addresses available.
Besides i have dhcp set up for an 8 hour turn around, due to the large amount of visitors we get.
So if it was not working, i would hear about it, quickly.
Anything else we can check in nagios?
It could be iptables blocking access
Run the following
iptables -I INPUT -i eth0 -p udp --dport 67:68 --sport 67:68 -j ACCEPT
benningtonr
ok, that worked, What would have caused iptables to start blocking again?
I had run that before and it has been working fine.
not really sure why they wouldn't stick. Have you changed anything? Installed new software?
benningtonr
maybe, i am always tweaking Nagios, love the software, just need to learn more.
