installation error
maxwellmiranda
installation error
Post by maxwellmiranda »
i am getting the following error while installing nagios XI on redhat linux RHEL6.3 64bit.
Configuring Yum...
package centos-release is not installed
ERROR: Please add the 'Optional' channel to your Red Hat systems subscriptions.
Re: installation error
Please, follow the steps outlined on our wiki page:
http://support.nagios.com/wiki/index.ph ... ptions..22
You can do it in the GUI or you can do it from the command line:
View all available repos on the system, including the disabled ones.
yum repolist all
Find the repo and install it. You may run something similar to this (depending on your system):
rhn-channel --add --channel=rhel-x86_64-server-optional-6
Hope this helps.
