My nagios doesn't start
slimix00
Post by slimix00 »
I type the command : nagios -v nagios.cfg
Nagios 3.0.6
Copyright (c) 1999-2007 Ethan Galstad (http://www.nagios.org)
Last Modified: 10-21-2007
License: GPL
Reading configuration data...
'Whats New' section to find out what has changed
So when I put : /etc/init.d/nagios start
>>>starting nagios :CONFIG ERROR! start aborted.Check your nagios configuration
I really need your help
thank you
Re: My nagios doesn't start
Post by slansing »
Use the following to verify your configuration, it should also point to exactly where the issues lay:
