Simple question
benningtonr
Simple question
What is the difference between response time and ping time?
Re: Simple question
HTTP response times would be how long it takes for your web server to respond with a request, while the Ping times are just a basic connectivity check. If the webserver crashed or wasn't running, HTTP would be critical while the Ping check might still be ok.
