Restart NCP Listener issue
Post Reply
dancormack
Post by dancormack »
I have followed the instructions to install the NCPA listener via the repository for a system running Oracle Linux 8.8. The instructions state that I am to run the following command after configuring the token in the config. The command is not found
sudo /etc/init.d/ncpa_listener restart
sudo: /etc/init.d/ncpa_listener: command not found
I tried using systemctl but the service ncpa_listener is not found. Please advise how to restart this.
bbahn
Re: Restart NCP Listener issue
Post by bbahn »
Hello @dancormack,
If you cannot find ncpa_listener, you are likely using NCPA 3. Is this the case?
NCPA 2 has two processes: ncpa_listener and ncpa_passive
NCPA 3 has one process: ncpa
So if you are trying to restart NCPA 3, you should instead use
systemctl restart ncpa
dancormack
Thank you! This has solved the issue. I guess the instructions need updating.
swolf
Post by swolf »
dancormack wrote: Thu Feb 01, 2024 3:41 pm Thank you! This has solved the issue. I guess the instructions need updating.
Hi @dancormack, glad to hear your issue is solved! I wasn't able to find anything on our public sites that still referred to just NCPA 2's management commands - if you have a moment, could you point us to where you found the outdated documentation?
-Sebastian
Post Reply
