I have NRPE and Nagios Plugins running on remote servers. Everything is functioning fine, but every now and then (seems random) I will notice service connection errors from Nagios XI. The problem is that the owner of the /usr/local/nagios AND /usr/local/nagios/libexec folder changes to 34806.34806 instead of nagios.nagios
The root solution to fixing this problem is re-adding the nagios user again:
./usr/sbin/useradd nagiosIn the meantime, any idea as to what could be causing this?
Regards
Phil
I'm using RHEL release 6.3 server. Linux 2.6.32-279.el6.x86_64 x86_64 with Proxy
