Elasticsearch Database Offline
randy-ringnalda
My Nagios Log Server instance keeps having it's elasticserach service stop. This only happened after we changed domain controllers. I have updated the resolv.conf to list the new nameservers. Thoughts?
Oliviajsdkf
Re: Elasticsearch Database Offline
Here are a few additional steps you can consider to troubleshoot and potentially resolve the issue:
Check Elasticsearch Logs: Review the Elasticsearch logs to see if there are any specific error messages or clues as to why the service is stopping.
Verify Network Connectivity: Ensure that the Nagios Log Server can communicate properly with the new domain controllers and that there are no network issues causing disruptions.
Check Elasticsearch Configuration: Verify the Elasticsearch configuration files to ensure that they are correctly set up, especially after the domain controller change.
Restart Elasticsearch Service: Try restarting the Elasticsearch service manually to see if it starts up without any issues. contexto
Monitor System Resources: Check the system resources (CPU, memory, disk space) to ensure that no resource constraints are causing Elasticsearch to stop unexpectedly.
Might want to check host/IP resolution and look at the ES log file.
- jmichaelson
run journalctl -xeu elasticsearch.service to see the log messages it has emitted.
-Jason
-Jason
