Hey there,
already roamed through dozens of postings here - but unfortunately none of them helped me solving this problem. Maybe one of you got another idea which helps me?!
I'm using check_nrpe to NSClient++ for Monitoring some Windows Servers.
"Normal" Checks (Disk/CPU/Memory/...) all working fine and reliable, but the "Check HyperV Replication Status" Check is flapping massively. About every other check it gets "Socket Timeout" ... Already tried different Versions of check_nrpe - example:
So it's completely random when it fails and when it succeeds. When executing the Check Hyper-V Replica PS Script on Server it always responds in time (5-15 seconds) and never failed / timeout.
The NSClient project is not owned or maintained by Nagios. NSClient++ is a third party agent that we do not develop or support and we are encouraging our customers to migrate to the Nagios Cross Platform Agent (NCPA) which is being developed by Nagios and will be supported moving forward.
If you still want to use NSClient, you can try using an older version of the check_nrpe plugin, but we suggest trying NCPA.
If you are still trying to use NSClient++, I recommend checking the nsclient log file found in the same directory as your nsclient executable. There should be more information about what's going wrong there.
