INSTALLATION ERROR!
Post Reply
pudheer
INSTALLATION ERROR!
Post by pudheer »
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './3-dbservers'
root@nagiosxi-ThinkCentre-M93p:/home/nagiosxi# chmod +x install.shysql -u root
chmod: cannot access '+x': No such file or directory
chmod: cannot access 'install.shysql': No such file or directory
chmod: cannot access 'root': No such file or directory
bbahn
Re: INSTALLATION ERROR!
Post by bbahn »
Hello @pudheer,
It seems your CLI isn't properly handling the chmod command. What OS are you trying to install on?
Post Reply
