error when execute make all from "Make and Install Nagios NRPE"
Post Reply
juairy15
Post by juairy15 »
Hi, I get an issue when I try to install nrpe service. I am following the instructions from (https://access.redhat.com/documentation ... eph-nagios)
we are red hat 9
error:
[root@su0960 nrpe-3.1.0]# make all
cd ./src/; make
make[1]: Entering directory '/root/nrpe-3.1.0/src'
gcc -g -O2 -DHAVE_CONFIG_H -I ../include -I ./../include -o nrpe ./nrpe.c ./utils.c ./acl.c -lssl -lcrypto
./nrpe.c: In function ‘init_ssl’:
./nrpe.c:418:22: warning: implicit declaration of function ‘get_dh2048’ [-Wimplicit-function-declaration]
418 | dh = get_dh2048();
./nrpe.c:418:20: warning: assignment to ‘DH *’ {aka ‘struct dh_st *’} from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
./nrpe.c:420:17: warning: ‘DH_free’ is deprecated: Since OpenSSL 3.0 [-Wdeprecated-declarations]
420 | DH_free(dh);
In file included from /usr/include/openssl/dsa.h:51,
from /usr/include/openssl/x509.h:37,
from /usr/include/openssl/ssl.h:31,
from ../include/common.h:29,
from ./nrpe.c:28:
/usr/include/openssl/dh.h:204:28: note: declared here
204 | OSSL_DEPRECATEDIN_3_0 void DH_free(DH *dh);
./nrpe.c: In function ‘handle_conn_ssl’:
./nrpe.c:1871:25: warning: ‘ERR_get_error_line_data’ is deprecated: Since OpenSSL 3.0 [-Wdeprecated-declarations]
1871 | while ((x = ERR_get_error_line_data(NULL, NULL, NULL, NULL)) != 0) {
In file included from ../include/common.h:31,
from ./nrpe.c:28:
/usr/include/openssl/err.h:425:15: note: declared here
425 | unsigned long ERR_get_error_line_data(const char **file, int *line,
./acl.c: In function ‘add_ipv4_to_acl’:
./acl.c:144:25: warning: implicit declaration of function ‘logit’ [-Wimplicit-function-declaration]
144 | logit(LOG_INFO, "add_ipv4_to_acl: checking ip-address >%s<", ipv4);
./acl.c: In function ‘is_an_allowed_host’:
./acl.c:563:46: warning: ‘__builtin_memcmp_eq’ specified bound 16 exceeds source size 8 [-Wstringop-overread]
563 | if (!memcmp(&addr6.sin6_addr, &host, sizeof(addr6.sin6_addr)))
./acl.c:488:42: note: source object declared here
488 | int is_an_allowed_host(int family, void *host)
/usr/bin/ld: /tmp/ccVpMRNH.o: in function `init_ssl':
/root/nrpe-3.1.0/src/./nrpe.c:418: undefined reference to `get_dh2048'
collect2: error: ld returned 1 exit status
make[1]: *** [Makefile:48: nrpe] Error 1
make[1]: Leaving directory '/root/nrpe-3.1.0/src'
make: *** [Makefile:66: all] Error 2
Can you help me to avoid this?
ssunga
Re: error when execute make all from "Make and Install Nagios NRPE"
Post by ssunga »
Hey @Juairy15, thanks for reaching out. It looks like there are problems with OpenSSL 3.0. Here are some things I'd try off the bat:
Check if you have an older version of OpenSSL available in your repositories or you can download it:
sudo yum install openssl1.1-devel
And using this older version:
export PKG_CONFIG_PATH=/usr/local/openssl1.1/lib/pkgconfig
export LD_LIBRARY_PATH=/usr/local/openssl1.1/lib
Then try make clean and make all to clean the previous build and try again.
There are also compatibility libraries you can try if that doesn't work:
sudo yum install compat-openssl10-devel
Post Reply
