API monitor
Post Reply
mandar18
API monitor
Post by mandar18 »
Hello team,
I want to monitor API in Nagios core.
How can this be done?
I don't have any details other than the API link.
The API link is in JSON
MaterazziSan
Re: API monitor
Post by MaterazziSan »
You can use this plugin https://nagios-plugins.org/doc/man/check_http.html
Best regards
mandar18
Re: API monitor
Post by mandar18 »
It does not work with HTTP, although other sites work by using HTTP.
Can we do it by using any plugin of rest API other than HTTP?
DoubleDoubleA
Re: API monitor
Post by DoubleDoubleA »
Hi @mandar18,
When asking for help on how to monitor, it is very useful to share what exactly you want to monitor for.
You mention json and an api, are you looking to parse a json api return and look for a specific value in that?
If so, you might look at https://exchange.nagios.org/directory/P ... on/details or https://exchange.nagios.org/directory/P ... s)/details or https://github.com/drewkerrigan/nagios-http-json .
Aaron
Post Reply
