jquery vulnerability showing on AIX
Post Reply
kbauma01
Post by kbauma01 »
Hello everyone,
Our vulnerability scanning tool is coming back with JQuery 1.2 < 3.5.0 Multiple XSS (CVE-2020-11022) but only on our AIX servers. I'm curious if anyone seen this.
https://server1:5693/static/js/jquery.3.4.1.min.js
That .js file is in /usr/local/ncpa/listener/static/js/jquery.3.4.1.min.js on all those servers.
Looking around (googling), it looks like there is a 3.5.0 version. Would it break anything if that was upgraded?
jsimon
Re: jquery vulnerability showing on AIX
Post by jsimon »
Hi @kbauma01,
I checked and it looks like we ship a newer version of jquery (3.5.1) with NCPA as of a while ago, I believe you should be fine to upgrade this. As always I'd recommend taking a VM snapshot before making changes.
kbauma01
Post by kbauma01 »
Thanks @jsimon
Is there a newer NCPA agent for AIX? The one I see is 2.2.1.
jsimon
Post by jsimon »
We currently are not producing AIX packages for NCPA. As NCPA is maintained as open source software, you could try building a newer version in house if there are specific requirements you need to meet. Another option would be to look at migrating to NRPE, if that suits your use case better.
betterwound
Post by betterwound »
jsimon wrote: Tue Sep 10, 2024 3:02 pm We currently are not producing AIX packages for NCPA. As NCPA is maintained as open source software, you could try building a newer version in house if there are specific requirements you need to meet. Another option would be to look at migrating to NRPE, if that suits your use case betterstickman hook
Hopefully there will be AIX packages for NCPA soon. Because I am having some problems and need AIX :(
tim620
Post by tim620 »
I would also like to see a newer version of NCPA for AIX. We use the NCPA agent on all our different platforms, including AIX.
bbahn
Post by bbahn »
I'll reference my other post on this topic here: viewtopic.php?p=360003#top
minakyliem
Post by minakyliem »
Another thing I'd want to see is an updated NCPA for AIX. Every one of our systems, including AIX, makes use of the NCPA agent.
Post Reply
