I recently posted the check_pctgroup plugin to the Exchange.
I uploaded images of the check and output states to the gallery but, they are not being displayed properly.
Here's what I get
I have tried removing the PNG images and replacing them with JPG but, the updates have not been processed at this time.
--SN
Nagios Exchange | Problem displaying uploaded images from the gallery
DoubleDoubleA
Re: Nagios Exchange | Problem displaying uploaded images from the gallery
Hi @snapier3,
I can confirm that behavior. We'll take a look.
Aaron
Aaron
Hi snapier3,
I can see that you were able to replace PNGs with JPGs in your listing, however they don't show up. I am not sure if they somehow got corrupted during the upload. It's hard to say. When I try downloading them, they show empty (0 bytes).
Can you upload them here, on the Nagios support forum?
I will try uploading them myself. If I am not able to do so for some reason, at least I could remove the corrupted images from your listing, so that you could try uploading them one more time. I am sorry for the inconvenience!
Thanks!
Thanks!
For Sure!
Here you go... Much appreciated,
--SN
--SN
Hmm, I uploaded the images myself, and the new images didn't show either. I will have to talk to our IT team about it. I will keep you posted.
