Ok, after installing Nagios Core 4.5.7 I had to see the big promotion for Nagios-CSP.
But what is the "Promotional License Key" good for?
Trying with trial it is not accepted. And for enterprise you need much more than this key.
And free is free without key...
And it is absolutely not intuitiv.
I remember when I first tried PRTG. This was really impressing.
After auto-discovery I found my hosts.
In Nagios-CSP (XI) I tried auto-discovery and now I'm still wondering where the hosts are?
Nagios CSP promotion
DoubleDoubleA
Re: Nagios CSP promotion
Hi @kuchenmann,
The CSP version of XI will get you a personal version of a 50-node XI with Enterprise features. It will be released soon.
Aaron
Aaron
markmillernp
I see that the Nagios CSP release is available, so I downloaded and installed it.
Which license type should I use for the CSP version? I can pick either Trial, Licensed, or Free - I assume that there is a special CSP license that I need to use.
gwesterman
Use the Licensed license. The key is "CSP50". Have fun!
kuchenmann
Well, I found it there:
http://ip-address/nagiosxi/admin/?xiwindow=license.php
and entered the key: 25YEARSOFNAGIOS!
kuchenmann
But it is still not clear, what does "Upgrade to a commercial license with professional support for as little as $199!" mean?
50-Node $199
200-Node $499
Unlimited Node $999
Is this the price for one month, one year, forever?
50-Node $199
200-Node $499
Unlimited Node $999
markmillernp
This license key is working, thanks!
I can only speak to one of the benefits of the license - which would be professional support. With the standard CSP license, you won't have any support entitlements available to you, should you need help with your system; you're on your own. If I learn more specifics I'll post back here.
Best Regards,
Cory Norell
Best Regards,
Cory Norell
