Azure netapp files
Azure netapp files
Hi I have used nagios core for a long time but struggling with things so have a trial running of nagios XI. I am trying to see if this can monitor an Azure netapp files we have setup. If it can is there a guide anywhere for setting it up as not been able to find anything
Re: Azure netapp files
Hi @liam,
Can you provide more information about what you're looking to monitor with Netapp Files? I don't believe we have a complete solution for Netapp Files, but depending on your goals you may be able to meet your needs with NCPA and a custom plugin.
