Hello, I have an issue with the Nagios XI dashboard. When I try to check the service for my E: drive on a server, it shows a negative percentage. I should clarify that my drive has a capacity of 40 TB, and the details display this message:
E:\ Label: """" Serial Number """":
-80% used (20052082MB / -2514834MB) (<80%) : OK
I tried deleting the service and reconfiguring it but i had the same problem.
Any Solutions?
Negative Percentage on my E: Disk Drive Service
Pablo_Gurmi
- jmichaelson
Re: Negative Percentage on my E: Disk Drive Service
What kind of check are you using for it? e.g., NCPA? It's looking like the problem is that the drive is showing a negative capacity, indicative of the disk size overflowing some integer value somewhere. I'm trying to get an idea of where to start looking.
-Jason
-Jason
Pablo_Gurmi
Hi sorry for no response i used SNMP but i resolved the issue upgrading a plugin of check_snmp_storage.pl and deleting the old one
Glad to hear you found a solution and thanks for sharing for others to also find. I'll go ahead and mark this as completed. If there's anything else we can help with let us know!Pablo_Gurmi wrote: ↑Wed Dec 04, 2024 2:45 pm Hi sorry for no response i used SNMP but i resolved the issue upgrading a plugin of check_snmp_storage.pl and deleting the old one
