Access nagiosxi directly instead of https://<ip>/nagiosxi
Post Reply
jithin@saturnme.com
Post by jithin@saturnme.com »
I need to access Nagios XI directly, and the URL should be https://<ip>/ instead of https://<ip>/nagiosxi. Please let me know the steps to achieve this. We are using the latest version of Nagios XI.
danderson
Re: Access nagiosxi directly instead of https://<ip>/nagiosxi
Post by danderson »
Thanks for reaching out
Unfortunately, right now, you won't be able to do this with the Neptune and Neptune Light themes. Modern and Modern Dark should work with this.
You need to modify the apache configuration to change the document root from whatever it is currently (most likely /var/www/html) to the html directory of nagiosxi (typically /usr/local/nagiosxi/html). On CentOS 9, the apache configuration is at /etc/httpd/conf/httpd.conf
Then you will have to modify the nagiosxi specific httpd configuration file. On CentOS 9 that's in /etc/httpd/conf.d/nagiosxi.conf. You will have to comment out the Alias /nagiosxi "/usr/local/nagiosxi/html" and also edit the mod_rewrite section. The original will say something like
RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
RewriteRule nagiosxi/api/v2/(.*)$ /usr/local/nagiosxi/html/api/v2/index.php [QSA,NC,L]
and you have to change it to
RewriteRule api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
RewriteRule api/v2/(.*)$ /usr/local/nagiosxi/html/api/v2/index.php [QSA,NC,L]
If you have SSL configured you'll also have to do the above change in the SSL conf file, which is at /etc/httpd/conf.d/ssl.conf on CentOS 9.
Then you will have to edit the nagiosxi config file. This is normally at /usr/local/nagiosxi/html/config.inc.php. You will change
$cfg['base_url'] = "/nagiosxi";
to
$cfg['base_url'] = "";
You should be able to access the user interface at this point. So you should then change the Program URL and External URL values in Admin -> System Config -> System Settings
Following these steps worked for me, so let me know if you run into any issues.
Post Reply
