I am trying to add a CA Cert using the "Add Certificate" in the GUI. When I paste in the certificate information and click 'SUBMIT' I receive a 500 error in the logs and a pop up screen saying "Could not write to /certs".
Any suggestions on how to fix this issue?
LDAP/AD Integrations
gwesterman
Re: LDAP/AD Integrations
Hi @sfarrell,
What distro are you on?
If on Ubuntu / Debian, try running these:
else try these:
Thank you!
chmod 0775 /etc/ldap/certs
chmod 0775 /etc/ldap/cacertsCode: Select all
chmod 0775 /etc/openldap/certs
chmod 0775 /etc/openldap/cacerts-
fertilecloaked
This usually isn’t an LDAP/AD issue — it’s a permissions problem.
The GUI runs as the web server user (typically apache), and the error means it can’t write to the certs directory.
Things to check quickly:
Verify ownership and permissions on the certs directory (commonly something like /usr/local/nagioslogserver/www/certs):
Make sure the filesystem isn’t read-only and isn’t full.
If SELinux is enabled, temporarily test with:
If that fixes it, you’ll need proper SELinux context rules instead of leaving it disabled.
After fixing permissions/SELinux, try adding the cert again.
chown -R apache:apache /usr/local/nagioslogserver/www/certs
chmod 755 /usr/local/nagioslogserver/www/certs
setenforce 0
