LS error
Post Reply
tryingtobeIT
LS error
Post by tryingtobeIT »
Hi
Getting this LS error - screen shot attached. It is not refreshing. It has been sitting at this same screen for at least two minutes.
lgute
Re: LS error
Post by lgute »
Hi @tryingtobeIT,
Thanks for reaching out. Have you tried reloading the page manually? If that doesn't work, I would try removing /waiting from the url and then hit the enter key.
If that does not work, please try the following and let us know what you get.
systemctl start elasticsearch
ps aux | grep java
tail -n 50 /var/log/elasticsearch/*.log
curl -XGET 'http://localhost:9200'
java -version
which java
rpm -qa | grep java
cat /etc/*-release
-Laura
Post Reply
