Integration of LS with XI
Post Reply
dunamis11
Post by dunamis11 »
NLS integration with XI is stalling on last step of the configuration wizard and all other steps completed. One item noted was potential firewall limiting this verification. Please advise.
jsimon
Re: Integration of LS with XI
Post by jsimon »
Hi @dunamis11,
Can you advise what the last button you clicked was labeled when you run into this? In addition, what OS/version are you running XI on, and what version of XI are you using?
Are you seeing any errors in your apache logs? Location for this will vary by OS.
Post Reply
