I have a lot of issues upgrading from 2024R1.1.5 to version xi-2024R1.2+
In another thread there was a suggestion about upgrading NDO.
I thought NDO was updated with the update of the version of XI, but maybe not...
I have a test system where I have upgrade from 2024R1.1.5 to 2024R1.4.1 and where I still see NDO 3.1.0.
Maybe it's the reason of my issues with my update.
What you think?
NDO 3.1.0 at version 2024R1.4.1
Re: NDO 3.1.0 at version 2024R1.4.1
Hey @Steph007steph007 wrote: ↑Wed Mar 12, 2025 8:11 am Hi,
What you think?
I'm taking a look at the code for upgrading ndo and it should run once every upgrade. The XI upgrade calls the NDO subcomponents folder and runs the upgrade as well. When you run an upgrade, during the NDO section do you happen to see a line that is something like this?
UPGRADE: Nagios Core version {your core version} isn't compatible with ndo-3.1.1
UPGRADE: Upgrade Nagios Core above 4.5.0
Here is a link if you would like to open a ticket with our support team.
https://support.nagios.com/
I have update manually NDO3 and it's working now.
