Monitoring FileMaker Pro Advanced
Post Reply
ludwighesse
Post by ludwighesse »
Does anyone know of a check to monitor FileMaker Pro?
Nagios calls itself the “Industry standard in IT infrastructure monitoring.” :evil:
sgardil
Re: Monitoring FileMaker Pro Advanced
Post by sgardil »
ludwighesse wrote: Thu Mar 13, 2025 1:59 pm Does anyone know of a check to monitor FileMaker Pro?
Hey @ludwighesse
The best place to look for third party plugins or software in general for Nagios products is the exchange. If you cant find anything there then you could always create your own plugin to monitor file maker if you are up for it. I'll attach a doc that may help if you do want to try to build your own.
https://nagios-plugins.org/doc/guidelines.html
ludwighesse
Thank you so much for your thoughts!
Post Reply
