Upgrade, Nagvis is down
Post Reply
cedric974
Post by cedric974 »
I just upgrade to 2024R1.4.1
All module in nagios seems to work.
I just have nagvis that is not working with this error page.
Error: (0) Creation of dynamic property NagVisException::$e is deprecated
URL: /nagvis/frontend/nagvis-js/index.php
File: /usr/local/nagvis/share/server/core/classes/CoreExceptions.php
Line: 37
#0 /usr/local/nagvis/share/server/core/classes/CoreExceptions.php(37): nagvisExceptionErrorHandler()
#1 /usr/local/nagvis/share/server/core/classes/GlobalCore.php(562): NagVisException->__construct()
#2 /usr/local/nagvis/share/server/core/classes/GlobalFileCache.php(157): GlobalCore->checkWriteable()
#3 /usr/local/nagvis/share/server/core/classes/GlobalFileCache.php(105): GlobalFileCache->checkCacheFolderWriteable()
#4 /usr/local/nagvis/share/server/core/classes/GlobalMainCfg.php(1534): GlobalFileCache->writeCache()
#5 /usr/local/nagvis/share/server/core/functions/core.php(36): GlobalMainCfg->init()
#6 /usr/local/nagvis/share/frontend/nagvis-js/index.php(41): require('...')
#7 {main}
Thank you for you help.
lgute
Re: Upgrade, Nagvis is down
Post by lgute »
Hi @cedric974,
Thanks for reaching out. A fix for this issue will be included in XI 2024R1.4.2.
In the meantime, you can download and install the updated version.
wget https://assets.nagios.com/downloads/nagiosxi/packages/nagvis-1.9.44-nagios.tar.gz
tar xf nagvis-1.9.44-nagios.tar.gz
cd nagvis-1.9.44-nagios
./install.sh
-Laura
cedric974
Post by cedric974 »
Thanks for your rapid answer.
It is ok now.
Thanks a lot
lgute
Post by lgute »
Hi @cedric974,
That's great! Thanks for letting us know the fix worked for you.
-Laura
Post Reply
