Error: Service has no hosts and/or service_description
Post Reply
adamsj
Post by adamsj »
So here's an odd one. My boss was trying to apply a configuration to silence some alerts, and he got this error:
<div>Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/aspace4.net.ualr.edu.cfg', starting on line 108)</div>
What's particularly odd about that is that the file in question is only eighty-four lines long.
I created this entry a couple of days ago, and it looks good to me when I inspect it. What gives?
John A
kg2857
Re: Error: Service has no hosts and/or service_description
Post by kg2857 »
You probably want to look in the cfg file for the things the error message says are missing.
adamsj
Post by adamsj »
Every entry in that file has both a host and a service description--thus my confusion.
kg2857
Post by kg2857 »
The error message mentions a line number in the cfg file. What do you see at or around that line?
I'd probably grep the service name, host, and description from the file since I imagine there are many services in the file.
Post Reply
