Check Linux OS version is outdated
Post Reply
MaterazziSan
Post by MaterazziSan »
Do you use some plugin for checking if your GNU/Linux OS version is not updated?
Do you create your own custom script?
Thank you!
Best regards
lgute
Re: Check Linux OS version is outdated
Post by lgute »
Hi @MaterazziSan,
Some users do create their own custom scripts. Here are the Nagios Plugin Development Guidelines, if you are interested.
Plugins created by other users can be found at the Nagios Exchange or Github.
For example, this plugin plugin checks for EOL.
-Laura
MaterazziSan
Thank you for your answer! ;)
Best regards
bbahn
Post by bbahn »
@MaterazziSan,
I'd say that this would be a very simple plugin to implement and you could even use a free AI service to generate such a plugin for you if you don't see a good one on exchange.
MaterazziSan
bbahn wrote: Tue Apr 29, 2025 5:08 pm @MaterazziSan,
Yes, no worries about this. It is clear to me and thank you!
Best regards
Post Reply
