MongoDB monitoring issue
Post Reply
lrnnetops
Post by lrnnetops »
Hi Team,
Following the Nagios upgrade from 5.7.8 to the latest version on Ubuntu, all services and hosts are functioning as expected, except for the MongoDB monitoring script (/usr/local/nagios/libexec/check_mongodb.py). This is due to Python version incompatibility. The old Nagios server (CentOS 7) uses Python 2.17, while the new server uses Python 3.12.3. Please provide an updated script compatible with the latest Nagios version and Python 3.12.3 that will allow us to monitor all MongoDB statistics as before.
Refer the below screenshot
(No output on stdout) stderr: File "/usr/local/nagios/libexec/check_mongodb.py", line 57
kg2857
Re: MongoDB monitoring issue
Post by kg2857 »
You might check if a python 2 is installed and if so edit the shebang line at the top of the script to use python2.
lrnnetops
Post by lrnnetops »
After installing Python 2.7.5 and updating the shebang, I'm getting a "No module named pymongo" error.
kg2857
Post by kg2857 »
You might want to install it.
lrnnetops
Post by lrnnetops »
do you have updated script that will support latest version of python.
kg2857
Post by kg2857 »
You may want to check the nagios exchange or the internet since this isn't likely to be a standard plugin.
lrnnetops
Post by lrnnetops »
CRITICAL - General MongoDB Error: command find requires authentication, full error: {'ok': 0.0, 'errmsg': 'command find requires authentication', 'code': 13, 'codeName': 'Unauthorized', '$clusterTime': {'clusterTime': Timestamp(1747916204, 2), 'signature': {'hash': b'\xf4=\x939\xe2\x97\xbc\xbc\xf7\xe3\xd5\x88\x91\x02\r\xc7\xdb\xd1\xc0\xe7', 'keyId': 7462416246990962689}}, 'operationTime': Timestamp(1747916204, 2)}
Nagios monitoring of MongoDB connections is reporting the above response.
I have configured using nagios configuration wizards
Post Reply
