Scheduled Backups Failing
Post Reply
bpg
Post by bpg »
Hi all
Hoping someone can assist me with an issue relating to our scheduled backup ...
It has recently come to light that the scheduled backups are failing.
The notification states the following:
View your full scheduled backup logs at /usr/local/nagiosxi/var/components/scheduledbackups.log to find out more details about the error. Your backup may have timed out, you can set a backup_timeout variable in config.inc.php to increase it.
Viewing '/usr/local/nagiosxi/var/components/scheduledbackups.log' shows the following:
 Backing up MySQL databases...
error: Found option without preceding group in config file: /etc/my.cnf.d/mysql-server.cnf at line: 1
mysqldump: unknown variable 'column-statistics=0'
Error backing up MySQL database 'nagios' - check the password in this script!
05-20-2025 14:45:40 ERROR: Scheduled FTP Backup Failed: Local file to transfer does not exist
As far as I'm aware, we are using MariaDB not MySQL .. if so, why are the errors reporting issues with backing up a MySQL DB?
Any help appreciated as my knowledge of Linux is lacking to say the least!
lgute
Re: Scheduled Backups Failing
Post by lgute »
Hi @bpg,
Thanks for reaching out.
What version of XI are you running and what distro/version?
You can check the "MySQL" version by running the following.
mysql --version
You should get a response like this (MySQL)...
mysql  Ver 8.0.41 for Linux on x86_64 (Source distribution)
...or this (MariaDB branch of MySQL)...
mysql  Ver 15.1 Distrib 10.5.29-MariaDB, for debian-linux-gnu (x86_64) using  EditLine wrapper
-Laura
Post Reply
