Good Morning,
I am trying to create service escalation process, and when I use a service that is defined by group access if there are any exclusions from the service the escalation apply fails.
Rick
Service Escalation Configuration Error
rickcote13
karinaaespa
Re: Service Escalation Configuration Error
Make sure excluded users are not part of the escalation path to avoid failures.
Italian Brainrot Clicker
