Alerts not sending
Post Reply
Josefius
Alerts not sending
Post by Josefius »
I have a Nagios Log Server verison 2024R1.3.4 running on RHEL 9 what will not send notification emails.
This server is configured to alert when someone logs in, the threshold settings:
Query:
"query_string": {
"query": "(type:\"syslog-nimble\") (host:\"10.<snip>\" OR host:\"10.<snip>\" OR host:\"10.<snip>\") AND (\"Status:Succeeded\" OR \"Status:Failed\") not (object:admin access type:su) not (access type:oauth client ip:127.0.0.1)"
The email method is SMTP to Office365, the host is allowed to relay.
I would appreciate any guidance,
Thanks, in advance.
Joe
jmichaelson
Re: Alerts not sending
Post by jmichaelson »
Hi Josefius
Do the alerts show up on the alerts page as an active alert?
-Jason
Josefius
Post by Josefius »
When I click "Alert History" and filter for "Warning" nothing shows up. it's all "OK". I know the query is highlighting what I am filtering for.
Josefius
Post by Josefius »
Would the not tagging as a 'warning' be related to this?
"filter": {
"bool": {
"must": [
"range": {
"@timestamp": {
"from": 1752774069635,
"to": 1752860469635
DoubleDoubleA
Post by DoubleDoubleA »
@Josefius are other alerts sending via email and it's just that this one isn't, or email alerts aren't functioning at all?
kg2857
Post by kg2857 »
If there are no alerts the issue isn't that alerts aren't being mailed, it's that they never happened. I'd change the thresholds and login as the user in question.
Post Reply
