Upgrade Ubuntu 22.04 to Ubuntu 24.04
Post Reply
riahc3
Post by riahc3 »
Hello
Im running the latest version of Nagios XI and I want to upgrade from Ubuntu 22.04 to Ubuntu 24.04.
Is this supported? What is the correct process?
cdepaulis
Re: Upgrade Ubuntu 22.04 to Ubuntu 24.04
Post by cdepaulis »
Yes, Nagios XI supports migration to a new OS version. To upgrade from Ubuntu 22.04 to 24.04, install the same version of Nagios XI on the new Ubuntu 24.04 system. Then, create a backup of your existing Nagios XI instance and restore it on the new system.
For detailed instructions, please refer to the following documentation.
https://library.nagios.com/support-tip ... e-with-xi/
https://library.nagios.com/documentatio ... nagios-xi/
Please let us know if you are having any trouble with this process.
- Caleb
riahc3
Post by riahc3 »
The issue with a new server is it requires reconfiguring Postfix, any custom plugins/scripts need to be manually migrated, things like Dell OpenManage Plug-in need to be reinstalled/recomplied, etc....It is a huge mess that requires time and patience
cdepaulis
Post by cdepaulis »
Things that aren't natively controlled by Nagios XI do indeed need to be set up again. While I’m not deeply familiar with the OS upgrade process itself, I have a few ideas that could help. I would ensure that you save or document any major configuration files when it comes to migrating something like Postfix. For the custom plugins you should just be able to make a tarball of /usr/local/nagios/libexec and transfer that file over to the new system. Other then that I would just make sure you have a list of all the things you need to setup on the new machine in order to ensure the migration goes smoothly.
I hope everything goes well if you have any other questions I'd be happy to try and help.
- Caleb
Post Reply
