Upgrade from 2024R2.1 to 2024R2.2 Issue
Post Reply
McTylan
Post by McTylan »
I'm running into a weird issue trying to upgrade to 2024R2.2. I've never had an issue running the following commands before:
cd /tmp
sudo wget -O upgrade.sh https://assets.nagios.com/downloads/nagiosxi/upgrade.sh
sudo sh ./upgrade.sh
But now I get this error:
Checking misc settings...
        Error: Unable to write to temp_path ('/tmp') - Permission denied
Total Warnings: 6
Total Errors:   1
I noticed this script is now changing my /tmp permissions to 1003:1003 as seen here:
drwxr-xr-x.  15 1003 1003 4096 Sep  4 06:24 tmp
I then tried to install the upgrade via this command set:
cd /tmp
sudo rm -rf nagiosxi xi*.tar.gz
sudo wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
sudo tar xzf xi-latest.tar.gz
cd nagiosxi
sudo ./upgrade
And it does the same thing. I also tried via the Web Interface and same thing.
mkimitch
Re: Upgrade from 2024R2.1 to 2024R2.2 Issue
Post by mkimitch »
The XI upgrade scripts shouldn’t change /tmp ownership; the error is because /tmp isn’t the standard sticky, world-writable temp dir.
Reset /tmp and verify:
sudo chown root:root /tmp
sudo chmod 1777 /tmp
# If you're on RHEL/CentOS/Rocky/Alma with SELinux:
sudo restorecon -Rv /tmp
# Verify (should show sticky bit and root ownership):
ls -ldZ /tmp
# expect: drwxrwxrwt. root root ... /tmp
If that looks correct, re-run the upgrade (HTTPS to avoid MITM/caching issues):
cd /tmp
sudo rm -rf nagiosxi xi*.tar.gz upgrade.sh
sudo curl -fsSLo upgrade.sh https://assets.nagios.com/downloads/nagiosxi/upgrade.sh
sudo bash ./upgrade.sh
If it still fails, try:
# If /tmp is mounted noexec:
sudo mount -o remount,exec /tmp
# Or avoid /tmp entirely:
cd /var/tmp
If none of the above resolves it, please open a Support ticket and include these outputs plus upgrade.log so the team can take a closer look:
ls -ldZ /tmp /var/tmp
mount | grep ' /tmp '
getenforce
id
df -h /tmp /var/tmp
cat /etc/os-release
tail -n 200 /usr/local/nagiosxi/var/upgrade.log
# If SELinux=Enforcing, any AVCs:
sudo ausearch -m AVC,USER_AVC -ts recent | audit2why
McTylan
Post by McTylan »
Thanks for your reply. None of that worked and it keeps trying to set the /tmp to 1003:1003. I've gathered the information you mentioned and opened a support case.
driftbossunblocked
Post by driftbossunblocked »
McTylan wrote: Thu Sep 04, 2025 12:49 pm Thanks for your reply. None of that worked and it keeps trying to set the /tmp to 1003:1003. I've gathered the information you mentioned and opened a support case.
Did you get help yet? I would love to hear how you solved this!
ajwilliamson
Post by ajwilliamson »
I get the same error on three different systems.
dscrimpsher
Post by dscrimpsher »
I am getting this same error also. I am running on Ubuntu 24.04.
Owner of the /Tmp folder is also 1003:1003.
I never noticed the perms on the /tmp before this so no telling if this is normal or not.
This is the complete output from the upgrade script:
/tmp/nagiosxi# ./upgrade
Checking install type...
Install type: source
Installation check passed.
IMPORTANT: Before upgrading, verify you have both a valid system backup as well as a configuration backup
of Nagios XI before continuing! More information about backing up and restoring Nagios XI can be found here:
NOTICE: Your Nagios XI license includes a test environment instance that allows you to verify successful upgrade and configuration
changes before applying them to your production environment. As a best practice for ensuring the reliability of your monitoring
systems, we advise you to upgrade your test environment before upgrading any production instances. More information on licensing
can be found here: https://assets.nagios.com/handouts/nagi ... Policy.pdf
Are you sure you want to continue? [y/N] y
Proceeding with upgrade...
Nagios XI Upgrade Log
DATE: Mon Sep 8 04:12:40 PM UTC 2025
DISTRO INFO:
Ubuntu
24.04
x86_64
chown: warning: '.' should be ':': ‘root.nagios’
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib/php/20230831/ixed.8.3.lin
Sourceguardian extension found for PHP version 8.3
Removing backup loader...
Sourceguardian extension already in php.ini
Checking required prereqs...
Please wait...
Operation timed out after 15001 milliseconds with 0 bytes received
OLD VERSION: 70100
mysql: [Warning] Using a password on the command line interface can be insecure.
Nagios Core 4.5.9
Last Modified: 2024-12-19
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 928 services.
Checked 50 hosts.
Checked 18 host groups.
Checked 15 service groups.
Checked 11 contacts.
Checked 8 contact groups.
Checked 184 commands.
Checked 21 time periods.
Checked 0 host escalations.
Checked 50 hosts
Checked 0 host dependencies
Checked 21 timeperiods
Total Warnings: 0
Total Errors: 1
***> One or more problems was encountered while running the pre-flight check...
directives and data definitions. If you are upgrading from a previous
dscrimpsher
I resolved this by updating the perms for /tmp.
My /tmp folder was:
drwxr-xr-x 17 1003 1003 4096 Sep 8 16:12 tmp
Not sure how that got changed from the default. This was a clean Ubuntu 24.04 server with only Nagios XI installed.
I ran these commands:
cd /
chmod 1777 tmp
chown root:root tmp
After my /tmp folder looks like this:
drwxrwxrwt 17 root root 4096 Sep 8 16:25 tmp
Then I was ablet o run the nagioxxi/upgrade.sh script normally.
...strange issue.
smeadows
Post by smeadows »
I had the same issue, and this worked for me:
cd /tmp/nagiosxi
chmod 1777 /tmp
bash -x ./upgrade
Previous upgrades we ran "sh ./upgrade" but that wasn't working this time. The command "bash -x ./upgrade" worked after fixing the permissions.
DoubleDoubleA
Post by DoubleDoubleA »
Hey everybody,
Regarding this upgrade issue, here at Nagios we made a number of updates and changes to our internal build process for our release artifacts, this is a bug with that new process where we mistakenly changed permissions. There are conditions where this bug does not appear on upgrade, and internally those were the conditions we had set up for testing, and we missed the bug.
The permission changes y'all noted here do indeed seem to work to get the upgrade done, and the feedback here helped us chase down the bug.
We're correcting the bug and the internal testing process. This one shouldn't appear again, and we'll have new latest XI artifacts soon.
Aaron
Product Development Manager
McTylan
Post by McTylan »
This was what Nagios Support had me do to resolve:
sudo su
chmod 1777 /tmp
systemctl restart nagios npcd
And then (still as sudo su):
mkdir /tmp/tmpinstall
cd /tmp/tmpinstall
chown -R root:root /tmp/tmpinstall
cd ./nagiosxi
./upgrade
Post Reply
