PS script for top CPU and Memory Usage
Post Reply
11abbidoa
Post by 11abbidoa »
We are 99% windows and our agents is NSClient++.
The monitoring only provide alerts for high cpu or memory.
Anyone here have good scripts to capture the top 5 or 10 services using the CPU or Memory?
It should capture the service name, pid and the comsumed resrouces in percentage.
Thanks in advance
kg2857
Re: PS script for top CPU and Memory Usage
Post by kg2857 »
exchange.nagios.org
tiffincrane
Post by tiffincrane »
oh i want this script too! thanks!
AngeloMileto
Post by AngeloMileto »
If you know how to create custom plugins, just make a quick powershell script and call that from XI. Unless there is a way to just execute PowerShell directly from XI.
Anyway, the PowerShell is simple:
(Get-Counter '\Process(*)\% Processor Time').CounterSamples
This will get you a list of processes with the CPU usage represented in the CookedValue parameter. So then capturing those:
(Get-Counter '\Process(*)\% Processor Time').CounterSamples | Where-Object {$_.CoodedValue -gt 0}
You could then filter out the idle and _total entries and sort/display whatever you want from there. Not sure what value that is in monitoring as it will report all the time even when CPU usage isn't high - unless you code it that way.
This should get you a start.
Post Reply
