I am trying to upgrade from 2024R1 to the latest version running RHEL 8, and I'm running to this error:
INSTALL: Nagios Mod-Gearman is being installed...
Updating Subscription Management repositories.
Red Hat Satellite Client 6 for RHEL 8 x86_64 (R 87 kB/s | 2.3 kB 00:00
Red Hat Enterprise Linux 8 for x86_64 - BaseOS 94 kB/s | 2.6 kB 00:00
Red Hat CodeReady Linux Builder for RHEL 8 x86_ 119 kB/s | 2.9 kB 00:00
Extra Packages for Enterprise Linux 8 - x86_64 146 kB/s | 2.3 kB 00:00
Red Hat Enterprise Linux 8 for x86_64 - AppStre 102 kB/s | 2.9 kB 00:00
Package gearmand-1.1.19.1-1.el8.x86_64 is already installed.
No match for argument: nagios-mod-gearman-1.0.1
Error: Unable to find a match: nagios-mod-gearman-1.0.1
Since gearmand 1.1.19 is installed, why is it looking for 1.0.1? Is there a way to bypass this check?
Upgrading NagiosXI - mod-gearman not found
DoubleDoubleA
Re: Upgrading NagiosXI - mod-gearman not found
Hi @chapmm3,
Thanks for your note.
Some questions: what type of install is yours? Source, rpm, or offline?
Did you happen to have gearmand installed already?
What happens if you run?
We added Nagios Mod-Gearman in 2024R2.1, so in between your previous version and latest. The installation script is looking for the version we supply.
Questions?
Aaron
dnf clean allWe added Nagios Mod-Gearman in 2024R2.1, so in between your previous version and latest. The installation script is looking for the version we supply.
Questions?
Aaron
Hi Aaron,
We are installing from RPM and I don't believe Mod-Gearman was previously installed.
I get the same error following dnf clean all. Is there a repository I can get v1.0.1 from?
Installing Nagios Mod-Gearman...
Red Hat Satellite Client 6 for RHEL 8 x86_64 (R 81 kB/s | 2.3 kB 00:00
Red Hat Enterprise Linux 8 for x86_64 - BaseOS 98 kB/s | 2.6 kB 00:00
Red Hat CodeReady Linux Builder for RHEL 8 x86_ 109 kB/s | 2.9 kB 00:00
Extra Packages for Enterprise Linux 8 - x86_64 150 kB/s | 2.3 kB 00:00
Red Hat Enterprise Linux 8 for x86_64 - AppStre 103 kB/s | 2.9 kB 00:00
DoubleDoubleA
@chapmm3 -
Did you ever resolve this issue? I'm having the exact same problem. I'm upgrade from source.
Karen
Last metadata expiration check: 0:05:05 ago on Mon 02 Feb 2026 04:48:56 PM EST.
Karen
nagios-mod-gearman needs to be in one of the repos so it's available to be installed. repos.nagios.com listed above might be the one.
