events correlation
Post Reply
wolfgang
events correlation
Post by wolfgang »
hi everybody,
i need to have a real correlation "motor" in Nagios Core.
The rules in Nagios are insufficient.
for example, i want to :
* when a router is down, i don't want to receive alerts from all hosts
* i want to be able to run script on alert
* i want to be able to modify some old events and resend them or others in the correlation's motor
* what about the console ?
etc......
So, if i want to write complex rules, can i plug NagiosLogAnalyzer and do correlation with NagiosLogAnalyzer fromevents coming from logs and from events coming from Nagios.
Is it possible ?
and how ?
Best regards
T Granier
Top
MaterazziSan
Re: events correlation
Post by MaterazziSan »
You can check https://assets.nagios.com/downloads/nag ... ncies.html for correlation events.
Best regards
kg2857
Post by kg2857 »
A few suggestions from your list.
You can limit the alerts when a host is unreachable in nagios.cfg.
Look into event handlers.
I'm not sure what the other two mean. The same with, "etc."
I don't know what NagiosLogAnalyzer is. There is Nagios Log Server, which can send log events to nagios that create alerts.
Post Reply
