Looking for a way to monitor for the program running on a Windows system.
Post Reply
Hasts1960
Post by Hasts1960 »
Looking for a way to monitor for the program running on a Windows system. The program is an executable called client.exe that loads into memory as a process when running. I have tried turning the process into a service with no luck.
While I can monitor for the process count I need to monitor weather or not the process is running and present a "critical" notification if the process is not running.
cdietsch
Re: Looking for a way to monitor for the program running on a Windows system.
Post by cdietsch »
Hi @Hasts1960,
The NCPA agent can monitor processes on windows. I recommend installing the NCPA agent on your windows server and using the XI wizard for adding the process to monitoring.
There are also quite a few posts on the forum seeking to do exactly this if you do a search. I will include one here now: viewtopic.php?t=56283
Good luck!
Cheers,
- Cole
lgute
Post by lgute »
Hi @Hasts1960,
As @cdietsch's suggested, NCPA is an excellent way to monitor Windows Processes (and Services). In addition, XI also has a few other wizards that will allow you to monitor Windows Processes and Services.
  • Windows WinRM
  • Windows SSH
  • Windows SNMP
-Laura
juliebender
Post by juliebender »
cdietsch wrote: Tue Dec 09, 2025 11:17 am Hi @Hasts1960,
Good luck!
Could you please share the NCPA agent installation file? I don't know where to find it.
cdietsch
Post by cdietsch »
Here is the link for NCPA which contains the download as well as documentation: https://www.nagios.org/projects/ncpa/
Good luck!
Cheers,
- Cole
cdietsch
Post by cdietsch »
Hi @deckskirl,
The link was shared above, but here it is again: https://www.nagios.org/projects/ncpa/
Good luck!
Cheers,
- Cole
Post Reply
