RESOLVED: Wizard install check set to inactive
chris_hird
Post by chris_hird »
We have built the installation wizard for our plug in using the sample and documentation provide. However we want to be able to set some of the checks as inactive on install from the wizard (we need to the customers to have access to the command but require them to configure the parameters before they are listed and run by Nagios). Looking through the documentation we cannot find anything that allows the check to be installed but set as Inactive?
Any one have an idea on how to do this.
Chris...
lgute
Re: Wizard install check set to inactive
Post by lgute »
Hi @chris_hird,
Thanks for reaching out.
In the case CONFIGWIZARD_MODE_GETOBJECTS: section of your wizard, you probably have code like this...
    $objs[] = array(
        "type" => OBJECTTYPE_SERVICE,
        "host_name" => $hostname,
        "service_description" => $description,
        "use" => "xiwizard_ncpa_service",
        "check_command" => "check_xi_ncpa!" . $theseopts,
        "_xiwizard" => $wizard_name);
For any checks that you want setup disabled, I believe you can just add a line like this to the array.
        "active_checks_enabled" => 0,
-Laura
chris_hird
This is for active_checks_enabled, we already use that in the wizard, but we want to be able to set it to inactive as it is installed?
tooltip...
<span class="material-symbols-outlined tooltip-info ccm-neptune-info" title="" data-original-title="Only active objects will be written to the config files and appear in Nagios. Inactive objects will only be shown in the CCM.">info</span>
Hope that makes sense.
Chris...
-SN
Post by -SN »
The configuration key:value pair for this is "is_active" it's bool set to 0 for inactive objects to be created and stored in the db.
Here are the templates I use for reference when developing for host and service objects. It's everything plus a couple :D
Hosts
    "host_name": "the.host.fqdn",
    "alias": "the.host.fqdn",
    "display_name": "the.host.fqdn",
    "address": "IP/the.host.fqdn",
    "use": "template name",
    "check_command": "check_command!$ARG1$!$ARG2$!$ARG3$!$ARG4$!$ARG5$!$ARG6$!$ARG7$!$ARG8$",
    "max_check_attempts": "#",
    "check_interval": "3",
    "retry_interval": "3",
    "check_period": "check_period",
    "notification_period": "notification_period",
    "notification_interval": "#",
    "contacts": "",
    "contact_groups": "",
    "is_active": "[1/0]",
    "_hostImpact":"",
    "_hostUrgency":"",
    "_onCall":"",
    "notes":"HOST OBJECT EXAMPLE (ALL FIELDS)",
    "notes_url":"url",
    "action_url":"url",
    "parents":"fqdns",
    "importance":"",
    "first_notification_delay":"",
    "notification_options":"[d,u,r,f,s]",
    "notifications_enabled":"[0/1]",
    "hostgroups":"hostgroup_names",
    "initial_state":"[o,d,u]",
    "active_checks_enabled":"[0/1]",
    "passive_checks_enabled":"[0/1]",
    "obsess_over_host|obsess":"[0/1]",
    "check_freshness":"[0/1]",
    "freshness_threshold":"",
    "event_handler":"command_name",
    "event_handler_enabled":"[0/1]",
    "low_flap_threshold":"",
    "high_flap_threshold":"",
    "flap_detection_enabled":"[0/1]",
    "flap_detection_options":"[o,d,u]",
    "process_perf_data":"[0/1]",
    "retain_status_information":"[0/1]",
    "retain_nonstatus_information":"[0/1]",
    "stalking_options":"[o,d,u,N]",
    "icon_image":"image_file",
    "icon_image_alt":"alt_string",
    "vrml_image":"image_file",
    "statusmap_image":"image_file",
    "2d_coords":"x_coord,y_coord",
    "3d_coords":"x_coord,y_coord,z_coord"
Services
    "service_description": "Os.Class.Category.Metric",
    "use": "nagiosxi-template-name",
    "check_command" : "check_command!$ARG1$!$ARG2$!$ARG3$!$ARG4$!$ARG5$!$ARG6$!$ARG7$!$ARG8$",
    "check_interval": "#",
    "retry_interval": "#",
    "check_period": "xi_timeperiod",
    "notification_period": "xi_timeperiod",
    "contacts": "contacts",
    "contact_groups":"contact_groups",
    "is_active": "[0/1]",
    "_serviceImpact":"",
    "_serviceUrgency":"",
    "_onCall":"",
    "hostgroup_name":"hostgroup_name",
    "display_name":"display_name",
    "parents":"service_descriptions",
    "importance":"#",
    "servicegroups":"servicegroup_names",
    "is_volatile":"[0/1]",
    "initial_state":"[o,w,u,c]",
    "obsess_over_service|obsess":"[0/1]",
    "freshness_threshold":"#",
    "low_flap_threshold":"#",
    "high_flap_threshold":"#",
    "flap_detection_options":"[o,w,c,u]",
    "first_notification_delay":"#",
    "notification_options":"[w,u,c,r,f,s]",
    "stalking_options":"[o,w,u,c,N]",
    "notes":"note_string",
    "notes_url":"url",
    "action_url":"url",
Happy monitoring,
--SN
chris_hird
Thanks for the information, looks like its exactly what we need.
Chris...
lgute
Post by lgute »
Hi @chris_hird,
I'm glad you have a solution. I'm going to lock this thread and mark it resolved for future users looking for this solution.
-Laura
