“Last Login” Time Not Updating After SSO Authentication
Post Reply
Gonzalezenks
Post by Gonzalezenks »
I noticed something unusual when users sign in through Single Sign-On (SSO). After the login process is completed, the “Last Login” field on the Manage Users page does not seem to reflect the current login time.
I’m trying to determine whether this is normal behavior when authentication happens through SSO, or if the “Last Login” timestamp is supposed to update regardless of the login method used.
Could anyone confirm if this is expected, or if it might indicate a configuration issue?
Thank you.
bbahn
Re: “Last Login” Time Not Updating After SSO Authentication
Post by bbahn »
Hello @Gonzalezenks,
What version of Nagios XI are you on? There was a fix for this issue on 2026R1. Are you continuing to encounter this after the fix was implemented?
Post Reply
