net-snmp exclude added by upgrade
Post Reply
wneville
Post by wneville »
Hello
It appears that doing an upgrade to NagiosXI via the command line inserts an exlude to the upgrade of net-snmp. I believe a while back someone said this was no longer necessary
Can this exclusion be removed from the upgrade script?
kfanselow
Re: net-snmp exclude added by upgrade
Post by kfanselow »
Hi wneville,
What version are you upgrading from and to and which OS distro are you using ? It looks like the net-snmp exclusion for RHEL8 was removed in 2024R1.3.1:
Removed exclusion of net-snmp package on RHEL/Oracle 8 systems [GL:XI#1066] – SG
https://www.nagios.com/changelog/nagios-xi/
Was it in your /etc/yum.repos.d/redhat.repo file prior to the upgrade ?
Post Reply
