Should this work in "Run Check Command" ?
Post Reply
davemulv1
Post by davemulv1 »
Using core config manager i have configured a service with a check command. The ARG1 value is a custom variable which is defined in a template for the service. This works in production, but testing the command with the "Run Check Command" button does not work. Seems like the variables from the template do not carry over. If I fill in the actual values it works.
Dave
DoubleDoubleA
Re: Should this work in "Run Check Command" ?
Post by DoubleDoubleA »
Hi Dave,
I feel like that should work. We wrote an issue and will take a look.
Aaron
bbahn
Post by bbahn »
The Run Check Command is not respecting custom variables. As @DoubleDoubleA stated, we have filed an issue and will get this fixed.
Post Reply
