dashboard log size
Post Reply
michael.lewis
dashboard log size
Post by michael.lewis »
I have a dashboard view that shows all of my syslogs in a table but the table only takes up about half of the usable space. How can I get it to be 100% height and width?
jmichaelson
Re: dashboard log size
Post by jmichaelson »
You can grab and resize the table panel by using the resize tools at the bottom left and right corners of the table (and any other panel you need to resize from the default sizes). Then save your dashboard, of course.
-Jason
Post Reply
