Problems with check_cisco_ping_ssh
esarsa
Post by esarsa »
I have problems with check_cisco_ping_ssh pluglin
#!/usr/bin/perl
# Usa la libreria Net::SSH de http://www.stupidfool.org/perl/net-ssh/
# Uso: /usr/local/sbin//usr/local/sbin/check_cisco_ping_ssh <host> <port> <user> <pass> <ip> <warn> <crit>
use strict;
use Net::SSH::Perl;
$ENV{'HOME'} = '/var/lib/nagios/';
my $router=$ARGV[0];
my $puerto=$ARGV[1];
my $usuariort=$ARGV[2];
my $clave=$ARGV[3];
my $ip=$ARGV[4];
my $warn=$ARGV[5];
my $crit=$ARGV[6];
my $sesion_ssh = Net::SSH::Perl->new($router, protocol=>1, cipher=>'DES', port=>$puerto, debug=> 'false');
$sesion_ssh->login($usuariort, $clave);
my $comando="ping $ip";
my($salida, $salida_error, $valor_exit) = $sesion_ssh->cmd($comando);
$salida =~ /Success rate is (\d*) (.*)/;
my $rate=$1;
if ( $rate <= $crit ) {
        print "PROBLEMA: Rate=$rate%\n";
        exit 2;
if ( $rate <= $warn ) {
        print "WARNING: Rate=$rate%\n";
        exit 1;
if ( $rate <= 100 ) {
        print "OK: Rate=$rate%\n";
        exit 0;
exit 3;
becasuse when I execute the plugin it presente me this error
"Waiting for server public key.
Connection closed by remote host. at /usr/share/perl5/vendor_perl/Net/SSH/Perl/SSH1.pm line 78"
I install:
yum install perl-Net-Telnet-Cisco.noarch
yum install perl-Net-SSH-Perl.noarch
yum install perl-Net-OpenSSH-Parallel.noarch
but the problem persists, somebody have any idea of this error
Reason: Added code wrapings
jsmurphy
Re: Problems with check_cisco_ping_ssh
Post by jsmurphy »
You may need to ask the plugin author about this one if you can find his details. It looks like it's never getting past the authentication stage, like the cisco device is expecting PSK auth rather than username/password... but as I said you would be best served asking the author on this one.
